Leicina Special SOS!!! Help.
#1 JeanLoup
JeanLoup
  • 2 posts
  • Digital Image Technician
Posted 11 September 2005 - 08:52 AM
Hello everyone, I'm new here, but have read several posts from time to time as a non member of this forum. In fact, it was due to the advice i read of the Lecinia Special camera given by others here on this board that I just baught one... It was a choice between a Leicina Special and a 7008 pro(with 6-70mm f1.4). And now I'm starting to wonder if i made a big mistake. I choose the Special because it is built like a tank, came with a decent looking 6-66mm lense, and the built in meter was fairly accurate; but most of all because apparantly it was a really easy camera to service yourself, clean, lube, etc. I thought, either I get the 7008 and knowing it is a more recently constructed camera, have to worry less about care (this model is in like new condition), or the Special and have the ability to care for it on spot, it has a smaller box-like form factor and runs on easily avalable AA batteries.
So I got the Special, and using the Repair guild I found on the net by super8wiki
http://super8wiki.co...Special:_Repair
I started to take the camera apart:
"Next carefully peel back the leather at the rop right corner (right looking at it) and at the right edge almost inline with the Leicinamatic contacts. You should find 2 deep holes with small sloted screws inside. Remove them but don't lose them! "
What the!? Okay, so seeing nothing resebling leather, I take a chance and assume that the black painted metal plate that is glued in the cartrage loading area and rests againsts the cart's left side when it is charged, and I remove it. And now I find at least 6-7 screws, none of them particularly in any deep holes. So now since I can't locate the special 2 screws wiki describes, I remove all but one (which seems to be missing the head of the screw). The camera now starts to fall apart, but is clearly held together by something else. Could it be this screw with no head? Or is that a screw that is screwed in from the other side and so I just see the bottom? !!! Panic, I have a camera half-dismantled and it doesn't bloody want to come apart, and doesn't fit the discription of Wiki's site. I take the camera back to the seller (Photo Baeumarches, Blvd. Baeumarche, Paris) and he offers to file the one screw that seems to be missing the head so as to unscrew it to continue the opperation.
Can anyone advise me on my situation. Apparintly it may not be too late to stop everything and put the purchase toward the 7008 pro. I'm afraid that with all the damn tinkering I'm going to break something in the Special, or misalign something - or that the screw turns out to be something else and we file down something we're not supposed to etc. By the way, there is now a screw (longest one in the inside wall of the cart cavity) that no longer seems to 'grip' the inside, as if screwing it into nothing.... Oh bloody hell!!!
I need a good camera, and I know that the Special and the 7008 both carry excellent reputations. Is it worth it to continue with the special or should I jump ship before it sinks and go for the 7008?
Help! Thanks!
JeanLoup
london_struck@yahoo.com
#2 santo
santo
Posted 11 September 2005 - 12:17 PM
I'm sorry to read this. Please stop and take it to somebody who can fix this. Your camera is probably now all out of alignment. Don't start filing things that aren't fitting back together for god's sake!
I hate to be critical at a time like this, but I have to ask why, when it didn't seem to you that things were as described on the wikki thing, you didn't just ask a question on the forum here or the filmshooting forum -- seeing as you were referenced from here or there? Or, if it was because you read a post from me on this camera, and that's why you bought it, you didn't just PM me when things weren't looking to be easy as described? Truly, opening up and doing a quick lube and clean is really easy. I don't understand why you would start taking out all kinds of screws and whatnot out of an area that doesn't remotely match the description? There is only one area on the camera that is "leather" or "leatherette" -- right on the front of it.
And also, why did you just buy a Special and not shoot a test cart to see how it operated? Did it really need a servicing right off the bat? Did you shoot a test cart? I didn't service mine until running into a jittery cart and having a pair of short films I'm sinking big bucks into on the horizon. It has performed flawlessly.
You made a smart move by buying a Special. Though the 7008 is no doubt a terrific camera as well. I'll stop this reply, I'm sure it can't come across as anything but critical/negative, and that's not really what you need to hear right now, as I'm sure this is an incredibly frustrating experience.
Edited by santo, 11 September 2005 - 12:23 PM.
#3 A.Oliver
A.Oliver
  • 348 posts
  • Croydon UK
Posted 11 September 2005 - 12:24 PM
Hi, wots wrong with your special? I assume you purchased the camera in non working order? Would advise you not to mess with the camera, send a private message to this guy, he knows all about specials, do a search for member 'sparky' send him an email i am sure he could advice or help. If you have trouble finding him send me a message and i will contact him for you.
Leicina special when working does produce a much more stable image than my fully serviced beaulieu 7008. If i had to choose it would be the leicina.
#4 JeanLoup
JeanLoup
  • 2 posts
Posted 11 September 2005 - 03:32 PM
The only thing vissibly wrong with the Special is that is was purchased by a complete idiot (it appeared to be fully funcional at time of purchase, for the record). Now that we have that cleared up, the reason I decited to attempt the clean/lube job was I have 1month garentee on the camera and I need something that works, not for 1 month, but for a while. Seeing as it was made in 73, and that I am at least the 3rd ower, the first being german i think, and the second was a French dude - I have orriginal reciet of the lens servicing dating 85 in Paris, and the thing seems to have been around on a number of trips looking at the miscilanous pamphlets and tickets found inside the Lietz bag it came in. So before I go off shooting expensive super8 that may end up with a (read, even more expensive) TC, I decited if I can't service the thing now, better not try it after the months up and there's no turning back, seing as it was a major point of purchase for me.
I adore the camera, it really is something. But now the only thing mine is, is in peices. I do not have internet access, so I print all the articles i can from forums, sites, etc and this purchase has been made after an accumulation of several documents compiled over time with a little research. Too bad wiki's site doesn't have photos to go along with the description.
I've reached a level of frustration that temps me to go all out in anyway possible for an exchange for the 7008. Not because I prefur it, but because at least I'm pretty sure it hasn't been butchered by a hack like me. If I knew someone who has better tinkering abilities and has already refurbished Leicinas, I'd be tempted to send it for an attemped rescue. But is it worth it... :P For the record, I have dismantled two previous cameras, a Nizo, and a Canon with no bad luck, and was able to clean and lube them, as well as my Goko editor, and a projector restored from heaps of old lube and a cruddy chain. I have vastly over estimated my abilities in this affair.
I still don't unerstand the refrence to leather. I don't have the camera with me but I don't remember anything even remotely resembling leather. It's all metal and some platic buttons. by the way, the plate comes off and though it is no longer as nice looking as before, I do think it is usable, as it is easily deformed, it should be not too difficult to un-deform, but then again, with my luck...
Thanks for the replies. I really blew it this time. If there is anyone who could help, I would be interested in discussing the issue. For those that can contact me, I'm in Paris.
Jean-Loup Bro
06.30.17.88.80
I will try to frequent the forums, though access to anything other than e-mail isn't extremely practical.
Thanks. Cheers mates. *goes off to cry in a dark corner*
#5 santo
santo
Posted 11 September 2005 - 04:03 PM
Don't be too hard on yourself, you just unscrewed a few screws and took off a plate you shouldn't have. I've read about people going out and trying to shoot feature length films without even testing their cameras or film stock they're using! Now that's an idiot! :lol: You just got overzealous in trying to make sure your camera was trouble free for a long time to come.
I'm surprised you can't find the leather(ette). I've attached an image of the front of the Special. The leatherette is right on front around the lens and the red Leitz symbol. You just have to gently peel that back to get at the top screw in the right hand corner, and then down below that, near the row of metal contacts is the second screw behind the leatherette, and then there's one on the back of the camera you can see with the battery box off. And that's it.
Edited by santo, 11 September 2005 - 04:04 PM.
#6 Alessandro Machi
Alessandro Machi
  • 3323 posts
  • California
Posted 11 September 2005 - 04:34 PM
I've never owned a Leincina however I have read that the filming speeds vary from model to model.
If these camera were hand made then year by year changes were most probably made to the camera, especially cosmetic changes.
Perhaps not all of the Leincina's have the leather covering.
