Hawks Anamorphic primes
#1 Gabriela Barraza
Gabriela Barraza
  • 2 posts
Posted 18 September 2005 - 06:57 PM
Good evening,
Do you know if a Clip on Matte box can be use in the Hawks Anamorphic primes?
Do we need a special size of reduction ring? Can we use the one for Arri Ultra primes?
I'm a producer, will be shooting next week in Santiago de Chile and my knowledge on Anamorphics is none. It's Sunday, a national holiday there, today and tomorrow and I can't get a hold of the AC.
Thank you in advance. Any light on the subject will be very much appreciate.
:unsure:
GBxx
#2 Christian Appelt
Christian Appelt
  • 470 posts
Posted 19 September 2005 - 12:08 PM
You should talk to Peter Martin or Boris Latman at Vantagefilm, the manufacturer of Hawk anamorphics.
PeterMartin@vantagefilm.com
BorisLatman@vantagefilm.com
www.vantagefilm.com
ph 0049 961 26795
#3 David Mullen ASC
  • 20069 posts
Posted 19 September 2005 - 01:57 PM
Also note that there are two series, Hawk Compacts and Hawk V-Series, which are much larger and heavier. And even within a series, I doubt they all have the same front element diameter. You probably need to be specific as to which Hawks you need to put a clip-on mattebox on, probably the wider-angles ones you plan on handholding, for example. I mean, you're not planning on shooting the whole movie with clip-on matteboxes, are you?
#4 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 20 September 2005 - 11:20 AM
You can put an LMB4 on all the lenses. The front diameter is identical from 50mm to 135mm.
