Soft FX filters
#1 Dimitrios Koukas
Dimitrios Koukas
  • 569 posts
  • Athens, Greece, London UK
Posted 24 September 2005 - 01:46 PM
Hello,
Most of the time I have used the tiffen's Pro-mists 1/4/and 1/2,(Not the Black ones),
what is their relation to similar filters in the market like Schneider optics or B+W if there is one.
Thank you in advance.
Dimitrios Koukas
#2 Jack Barker
Jack Barker
  • 90 posts
  • Ann Arbor, MI
Posted 24 September 2005 - 05:45 PM
I use the excellant Formatt 4x4's including
1/2 Black Supermist
#1 Black Supermist
1/4 Clear Supermist
#2 Black Net
Prior to that I used Tiffen screw-ins. In terms of softening and light loss, I can tell no difference whatever. I had a long conversation with a senior engineer from Schneider once and he pretty much confirmed that general equivalency exists throughout the industry. Formatt makes a big deal about the quality of their glass, while Schneider like to be thought of as cutting-edge, but I think the end results are all pretty much the same/
#3 Dimitrios Koukas
Dimitrios Koukas
  • 569 posts
Posted 25 September 2005 - 02:42 AM
1/2 Black Supermist
#1 Black Supermist
1/4 Clear Supermist
#2 Black Net
<{POST_SNAPBACK}>
Thanks for your reply.
Are u fun of airplanes m8? I hold a PPL.
Dimitrios
#4 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 06 October 2005 - 06:05 PM
Hello,
Dimitrios Koukas
Diffusion filters tend to come in two basic varieties; those that have a light-scattering substance in the glass, and those that have a texture to disturb the light path on the way to the lens. There are some that do both, and with different color qualities as well.
In general the light-scattering type like Tiffen's Pro Mist cause more flare or halation in the highlights than they do softening to image, relative to the filter's strength. They also lower the contrast more as you increase the strength (White Pro Mist fogging the blacks the most). Schnieder's equivalent are called "Frost."
The textured type uses the surface of the glass in the form of bumps or "lenslets" to diffuse the light path. These filters tend to soften or blur the image more than they cause flare or halation, and usually don't alter the contrast at all. Tiffen's version is called "Soft FX," and Schneider's are called "Classic Softs."
http://www.tiffen.co...t=Larger Format
http://www.schneider...fusion_filters/
#5 Jack Barker
Jack Barker
  • 90 posts
  • Ann Arbor, MI
Posted 06 October 2005 - 06:12 PM
Dimitrios
Yeah, me too. SEL, Night VFR.
Are those David Clark's you are wearing in your avatar?
Edited by Jack Barker, 06 October 2005 - 06:14 PM.
#6 Dimitrios Koukas
Dimitrios Koukas
  • 569 posts
Posted 07 October 2005 - 07:44 AM
Indeed! Happy flying m8.
Dimitrios Koukas
Thanks Mike,
Is it supposed that the schneiders are using better quality optics? (glass).
Dimitrios Koukas
#7 Michael Nash
Michael Nash
  • 3330 posts
  • Pasadena, CA
Posted 10 October 2005 - 04:03 PM
Well, that's what the Schneider reps will tell you! ;) But you'd have to test for yourself and see which results you like best.
