asa rating
10 replies to this topic
#1 Delorme Jean-Marie
Delorme Jean-Marie
  • 513 posts
  • paris, france
Posted 28 September 2005 - 04:00 AM
hi
on the specs this cam has an asa rating of 800 asa
what asa rating do you find on your agdv
without filters
with 1/8
with 1/64?
thanks
#2 Sampsa Huttunen
Sampsa Huttunen
  • 5 posts
  • Helsinki, Finland
Posted 07 November 2005 - 12:16 PM
hi
without filters
with 1/8
with 1/64?
thanks
As far as I know, the asa rating without any gain is 320.
Haven't tested with filters, but 1/8 should be -3 stops and 1/64 -6 stops.
#3 Vinod Raja
Vinod Raja
  • 22 posts
  • BANGALORE
Posted 02 December 2005 - 03:22 AM
Hi ! I rate the camera at 500 ASA without ND filters, 64 ASA with 1/8th ND. Arrived at this speed using my pentax digital spot meter on a 18% grey card to match the readings with my Minolta autometer III.
Thanks best
#4 Phil Brown
Phil Brown
  • 5 posts
  • New York, USA
Posted 20 December 2005 - 05:06 PM
ASA for DVX100
DVX100 guru Barry Green writes a great chapter on this in his "The DVX Book" a great tool for any DVX owner.
There is a lot of technical analysis and he lists the testing conditions - well worth reading. Testing was verified with a sekonic L-508C lightmeter in spotmeter mode, and a waveform monitor to guage camera response.
The general conclusion is that the DVX100 is variable but as a general guide, rate the camera at 640ASA in progressive and 1000ASA in interlaced mode and you will be within 1/2 stop of being accurate (diff between 400ASA and 640ASA is 1/2 stop and from 640ASA to 800ASA is about 1/4 stop).
Available light will cause variations - at f/2.8 progerssive he tested 400ASA in progressive and f/16 800ASA (and 1280ASA interlaced)
so... 640ASA progressive is a pretty safe call for most situations - if possible use DV Rack on a calibrated monitor or laptop to really see what the camera is recording.
Hope this helps.
Phil Brown
Video Production Melbourne
#5 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 13 January 2006 - 03:26 AM
Sorry, it's 1/3 of stop difference in both cases...
#6 Jamie Metzger
Jamie Metzger
  • 773 posts
  • San Francisco
Posted 19 January 2006 - 04:11 PM
ASA for DVX100
Hope this helps.
Phil Brown
That Helped me. My friend was rating it at 800, which isn't far off, but I'd rather go with 640.
Thanks.
#7 David Mullen ASC
Posted 19 January 2006 - 04:13 PM
I found the original DVX100 at 24P to closer to 320 ASA at 0db with a 1/48th shutter.
#8 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 20 January 2006 - 03:18 PM
I realize I made a mistake, though I can't edit..
it's 2/3 of a stop beetween 400 and 640 and 1/3 beetween 640 and 800, sorry
#9 G McMahon
G McMahon
  • 161 posts
Posted 08 August 2006 - 10:04 AM
I?m shooting at the moment with this camera. I am finding this time it is really sucking up the light. I admit, I never have shot it with the shutter on before but I didn?t think I would need as much light. Does certain scene file options steal more light than others or I am more light conscious now?
G.McMahon
#10 Phil Brown
Phil Brown
  • 5 posts
  • New York, USA
Posted 08 August 2006 - 10:59 AM
G.McMahon
Yes, some scene files do have settings that reduce response to light F5 & F6 progressive settings particularly.
The DVX100 is not a good choice in low light - I have been frustrated by it many times and seen $600 handycams blow it away - but with light of course, it's magnificent. You can try using video gain settings to improve light tresponse, but remember, you will increase the grain considerably.
#11 Andy Lehmann
Andy Lehmann
  • 7 posts
Posted 15 August 2006 - 11:25 AM
The ASA rating is something between 250-320 ASA (with cinegamma on and in 25p mode).
