Paul Cameron & Man of Fire
7 replies to this topic
#1 Hamid Khozouie
Hamid Khozouie
  • 61 posts
  • TEHRAN , IRAN
Posted 30 September 2005 - 05:36 AM
I saw MAN OF FIRE yesterday on dvd .I am very pleased with artistic work of Paul cameron.
In searching I can not find any article about cinematography of it.The only article which I know ; in ICG magazine is not available on line
Do you have any information about the technique of cinematography?
Negatives.......Cameras.......Process in lab........or......
Will be thank for your consideration.
#2 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 30 September 2005 - 06:04 AM
<{POST_SNAPBACK}>
If that's man on fire 2004.
Multi Cameras for action 8 sometimes more .
2 at 24 FPS 35mm Panavision Wide + Medium
1x 48 FPS 35mm
1x 100-150 35mm Arri 435 Close Ups
2x Hand cranked Arri 2C
2x 16mm Aaton minima
The hand cranked cameras also double exposed in camera and cross processed!
There are many threads about this!
Stephen
#3 Wendell_Greene
Wendell_Greene
  • 545 posts
Posted 30 September 2005 - 11:07 AM
"Man on Fire" was covered in the April 2004 issue of International Cinematographers Guidld magazine [ICG]
Film stocks:
5284 Expression - often pushed 1-2 stops for night and day interiors and to supplement with 5274 and 5248 for daytime, Cameron mentioned the '84 "had significant grain that just boiled in the high [lights]
Kodak reversal 5285 cross processed and pushed as needed
Cameras:
(2) 35mm Panavision Millenium XLs
(2) Arri 2C hand cranked
(1) Arri 435 HS
(2) 16mm Aaton XTR Prod
(1) 16mm Aaton A-Minima
A total of 17 cameras were used in the scene where the club explodes, 4 in fireboxes and one over a mile away to catch the explosion.
Lenses:
several 11-1 zooms
135-420 lenes
complete set of Mark II primes
Super 35 2:40 - special ground glasses were made for the 16mm cameras
As mentioned in a previous post, they would often back crank the cameras, sometimes stopping down the aperture, and [sometimes] covering the lenses and then exposing the film again.
Lighting: (partial)
12K HMI Pars
1200 HMI Pars
7K Xenons
2K
Practicals
Par Cans
Kino Flos
12 light maxi brutes, used on dimmers at times.
Additional Info:
Cameron favors Rosco Cal Color gels and used a combination he has employed on other films like "Gone in Sixty Seconds' [American Cinematographer article online at the AC site] for a night scene outside the club that Denzel Washington's character, Creasy, destroys in the building. Apricot and Cal Color 30 on 12K HMI Pars for a sodium vapor look and Full Plus Green and 1/2 Blue on other 12K's for a Mercury Vapor look. When Denzel goes inside the club, Cameron used 20 Data Flash heads around the room in a circular chase pattern and 50,000 watts of light from another dozen or so Lighting Strikes units, combined with 2 7K Xenons hitting a disco ball in the center of the room. Another 20 + HMI 1200 Pars and 2Ks accented the architecture of the building along with 50 or more fluorescent cool white tubes.
The practicals were accented with Cal Color Yellow 30 to dirty them up. Other bulbs were left bare and Kinos were hidden around the room.
#4 Tim J Durham
Tim J Durham
  • 742 posts
  • East Coast, Baby!
Posted 30 September 2005 - 12:53 PM
Film stocks:
Cameras:
(1) Arri 435 HS
Lenses:
several 11-1 zooms
135-420 lenes
Lighting: (partial)
12K HMI Pars
1200 HMI Pars
7K Xenons
2K
Practicals
Par Cans
Kino Flos
Additional Info:
<{POST_SNAPBACK}>
But seriously,
Could you give us a few details?
#5 Hamid Khozouie
Hamid Khozouie
  • 61 posts
  • TEHRAN , IRAN
Posted 03 October 2005 - 03:51 AM
Thanks for your very good informations.
But now, I dont know any use of DI process, or bleach by pass.
Why they used hand cranked IIC ?
Over & under in hand held camera work is for DI or IIC or.....?
#6 Mike Williamson
Mike Williamson
  • 534 posts
Posted 03 October 2005 - 09:42 AM
If you check the archives, there is an interesting thread about "Man On Fire" that I remember posting in, someone talked about Cesar Charlone (DP from "City of God") operating on the film, so have a look and see if you can find it.
To fill in a few more details, the film did go through DI at 2K resoultion at Company 3 with colorist Stefan Sonnenfeld. Paul Cameron did an initial color correction on the film in three days working with Sonnenfeld, after which Tony Scott came in and spent a few weeks making changes. At the end of that session, Scott brought Cameron in to look at the new version which apparently was much warmer and Cameron told him that it wasn't the film they had shot. In the end, Scott decided to go with the initial color correction that Cameron had done, and that's the film you saw. For more info, check out the article on DI's in ICG Magazine July 2005.
In terms of processing, I don't believe there was any bleach-bypass done. As Wendell notes, however, Cameron was pushing the film very aggressively, including at times the reversal stock that he was cross-processing (5285).
The hand-cranking is done with a modified Arriflex 2C and is not a digital effect. Hand-cranking allowed them to get flickering exposures and speed changes by cranking faster or slower. It gives the film a rough, jittery quality that you really can't approximate in any other way. If you look at the film, can you tell which shots are hand-cranked? If you can recognize them, see how those shots make you feel. I think they add to the tension and feel almost out of control at times.
Hope this information is helpful, I'd recommend ordering the back issue of ICG if you want to know more. Also, the special edition DVD has a documentary about the making of the film, I haven't seen it though so I don't know if it's worthwhile or not.
#7 Rolfe Klement
Rolfe Klement
  • 668 posts
  • London | LA
Posted 03 October 2005 - 04:55 PM
Rent or buy the special edition 2 disc DVD - it runs through the whole thing in the doco. There is also a multicam scene where Dakota gets kidnapped and they show and title camera and lens info about 6 or 8 cameras running at the same time in one window - now that was a 10 min film school! :)
thanks
Rolfe
#8 Hamid Khozouie
Hamid Khozouie
  • 61 posts
  • TEHRAN , IRAN
Posted 04 October 2005 - 03:56 PM
I AM VERY FASCINATED BY ALL INFORMATIONS
The only printed information is an article on ICG magazine april 2004. Unfortunately , I can not buy it online in Iran.
Can I take it by email or .....( scan of article )
