Time Lapse Software for DV
10 replies to this topic
#1 George Lekovic
George Lekovic
  • 69 posts
Posted 06 October 2005 - 07:39 PM
Does anybody know of a software that enables timelapse capture straight to the hard drive. Interval-recording option on small 3CCD DV cameras records few seconds every once in a while, as they are unable to capture one frame at the time.
But when camera is connected to computer via firewire it should be no proble for a computer to capture one frame at the time and make for nice time lapse photography. Is there a software that does this. Could still camera work too?
Thank you.
#2 Luke Prendergast
Luke Prendergast
  • 491 posts
  • Victoria Australia
Posted 06 October 2005 - 08:08 PM
Adobe Premiere has it. IStopMotion for Mac has it.
#3 Jay Gladwell
Jay Gladwell
  • 144 posts
  • Miami, FL
Posted 07 October 2005 - 07:20 AM
The only way to capture true time lapse is using something like the FireStore FS-4. It has the ability to record single frames for true time lapse. Connect it to the camera and you're good to go!
Any software that I'm aware of simply captures everyth Nth frame from normally recorded footage. The most you can shoot that way is an hour.
Yes, a still camera could work, but then you would have to convert all those still images into a frame sequence. It just time consuming.
Yes, there are many way to skin a cat--simulate time lapse--but if you want true time lapse and your taping some event that's longer than an hour, the FS-4 is the way to go.
Jay
#4 Tim J Durham
Tim J Durham
  • 742 posts
  • East Coast, Baby!
Posted 07 October 2005 - 07:41 AM
Jay
So you're saying those programs won't capture a frame at a time from a live camera feed?
#5 Jay Gladwell
Jay Gladwell
  • 144 posts
  • Miami, FL
Posted 07 October 2005 - 12:27 PM
What I said was: "Any software that I'm aware of..."
One piece of software that was mentioned and that was for Macs. Not being a Macite, I'm not familiar with it.
Jay
Edited by Jay Gladwell, 07 October 2005 - 12:32 PM.
#6 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 07 October 2005 - 02:51 PM
Jay
Adobe Premiere worked last time I tried!
Stephen
#7 Richard Boddington
Richard Boddington
  • 5508 posts
Posted 07 October 2005 - 03:20 PM
The best for this is:
http://www.framethief.com
I've shot some nice time lapse with this. Heck leave the computer at home and just record an hour of continuous roll of the subject and then run it through the time lapse mode into the computer and have Frame Thief sample the tape at the intervol you want. The benefit to this is that you can change the intervol with each pass.
R,
#8 Stuart Brereton
Stuart Brereton
  • 3345 posts
Posted 07 October 2005 - 03:49 PM
iStopMotion from Boinx software can do Timelapse via Firewire from DV, or from a few DSLRs.It's pretty cheap (about $35.00) I think it's Mac only, but I could be wrong.
#9 will
will
Posted 07 October 2005 - 06:48 PM
Still camera gives you 4k or better image size with good DSLR :)
there is free software for both mac and pc.
-will
#10 Richard Boddington
Richard Boddington
  • 5508 posts
Posted 07 October 2005 - 07:36 PM
Using a digital stills camera opens up a huge can of worms. Only a few on the market will be acceptable for time lapse. The reason is the shifts in white and black levels between shots.
A DSC was never designed to produce perfectly matching shots from one frame to the next. I know several people that have tried this and then had to spend huge amounts of time making the frames match using After Effects.
The only way to test your camera is to shoot say 24 shots of a white piece of paper under studio lights. Then import all 24 shots and build them into a quick time movie. Now playback the movie on a monitor. Is there flashing from frame to frame? If there is the camera won't work for time lapse.
You need to have 24 frames perfect with no changes in levels from frame to frame, so your movie should just look white with no changes. Some cameras will do this, others will not.
R,
#11 George Lekovic
George Lekovic
  • 69 posts
Posted 08 October 2005 - 01:01 PM
R,
That was the way I wanted to go woth in order to capture HQ footage. Do you know which cameras are acceptable and which are not. I have access to D10, S2 and S3.
Thank you.
