Krasnogorsk 3 vs Bolex h16
11 replies to this topic
#1 Mike Kaminski
Mike Kaminski
  • 60 posts
  • toronto
Posted 10 October 2005 - 09:02 PM
Hello. First post here.
Im wanting to get into shooting my own film, mostly to experiment and learn techniques and maybe even to shoot some shorts with. Im planning on getting my own 16mm camera and I'm relatively new to the market, having shot almost exlusively on Arri SR2, which is out of my price range. Im on a pretty tight budget. So with a little reading and shopping, basically the two cameras that keep coming up, that seem to be both durable, cheap and high quality are the Krasnogorsk 3 and the Bolex h16. I've shot on the bolex, which would be good enough for me, but ive never used the Krasnogorsk, but the stuff ive seen from it looks just as good if not better than Bolex material. Both of these cameras i know are highly recommended, and i seem to be leaning towards the Krasnogorsk. However, someone once told me that they are no good, that the image is unstable and I might as well shoot DV24p yada yadda yadda.
Anyway, what is peoples opinions on the matter here? Is there a better option for me to go with?
(sorry about the NOObish question BTW)
#2 Nate Downes
Nate Downes
  • 1638 posts
  • Florida, USA
Posted 10 October 2005 - 09:25 PM
I own a K-3, rock-solid images. It depends greatly on the camera involved, how they're maintained, etc. I prefer it over the Bolex, once properly tuned. (need to remove those damnedable loop formers however)
#3 Will Montgomery
Will Montgomery
  • 2072 posts
  • Dallas, TX
Posted 11 October 2005 - 12:10 AM
I wish there was a way for the K-3 to film without holding the button... like a Kodak K-100 where you flip a switch and it runs (until it winds down...). When on a tripod it would be nice to let it shoot without having to hold your finger on it constantly minimizing a chance of movement and for other applications when you can't always be holding it.
#4 Richard Tuohy
Richard Tuohy
  • 482 posts
  • Daylesford, Australia
Posted 11 October 2005 - 02:12 AM
What about using the very robust Kras-3 cable release!
#5 Bon Sawyer
Bon Sawyer
  • 56 posts
  • Perth, Australia
Posted 11 October 2005 - 07:00 AM
That's only for single-frame exposures (animation, timelapse, etc.), if I'm not mistaken.
I think the Tobin crystal motor has an on/off push-button, but that's quite a big step up.
-Bon
#6 Nate Downes
Nate Downes
  • 1638 posts
  • Florida, USA
Posted 11 October 2005 - 07:25 AM
-Bon
It is for single frame if you use the rear port. If you use the hole in the middle of the trigger, it's a trigger replacement and will allow you to run continuous runs until you run out of wind.
#7 Will Montgomery
Will Montgomery
  • 2072 posts
  • Dallas, TX
Posted 11 October 2005 - 10:47 AM
How about that? I never noticed that little hole in the trigger. I will try that out this week. Thanks for the info!
#8 Bon Sawyer
Bon Sawyer
  • 56 posts
  • Perth, Australia
Posted 11 October 2005 - 11:52 PM
Well there you go! I would never have thought to try it, and don't recall reading about it in the manual. Cheers!
-Bon
#9 daniel mahlknecht
daniel mahlknecht
  • 190 posts
  • Italy - South Tyrol
Posted 15 October 2005 - 01:38 PM
the krasnagorsk is supercheap, while a bolex costs quiet a bit more.
with the bolex anyhow you can atach easyly an electric motordrive, so you can make longer shots, and you can use a 400ft mag (on the bolex rx5 and the bolex sbm wihich are the two most interesting modells) but this only with electric motor.
the krasnagorsk can easyly be converted to super16, especially the one with the M42 screwmount, because centering the lensmount is not strictly necessary, as photografik lenses will always cover super16mm.
I would say that the bolex is much more a serious camera, but the krasnagorsk is much cheaper and also much handyer.
daniel
#10 Robert Glenn
Robert Glenn
  • 247 posts
Posted 18 October 2005 - 08:21 PM
daniel
Has anybody recentered the lens mount on the k3? Seems like it wouldn't be too difficult to do
Edited by RobertNC, 18 October 2005 - 08:22 PM.
#11 Will Montgomery
Will Montgomery
  • 2072 posts
  • Dallas, TX
Posted 18 October 2005 - 11:26 PM
Tried the release cable on the front button (never noticed that hole before!) and it worked while I pressed the cable release but wouldn't keep running if I let go.
It would just be nice for those shots when I don't want to hold the camera... just an "on/off" switch.
#12 Charles MacDonald
Charles MacDonald
  • 1157 posts
  • Stittsville Ontario Canada
Posted 18 October 2005 - 11:48 PM
Must admit ot never seeing a K3 up close :( But if it takes a normal cable release, your locak Camera Store (do those even exist in this digital age?) may have a release with a little knurled screw, that can be tightened to hold the relase in. Used in Still camera for taking long time exposures. :D
