Matte Boxes
9 replies to this topic
#1 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 11 October 2005 - 09:39 PM
What are the different uses of the 6x6 matte box and the 4x5? Is there some difference in the usefulness of grad filters? (I guess w/ a 6x6 grad you can really bring the line way down into the frame.) If I can afford to rent only one 2 stage mattebox, and one set of filters, which size should it be, if my widest lense will be 18mm? Shooting spherical, 1.85:1. So far, I've asked for the 6x6.
J
Edited by J-Ro, 11 October 2005 - 09:44 PM.
#2 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 12 October 2005 - 01:55 AM
The 4x5 swill cover the 18mm (at least if you are shooting Arri, but I suppose for Panavision as well). 6x6 are used for lenses with a bigger front diametre, like zooms or some anamorphic primes,
#3 Dimitrios Koukas
Dimitrios Koukas
  • 569 posts
  • Athens, Greece, London UK
J
6x6 is a good choice for this lenses,
One difference is that u need a filter to cover your lense.So if you have big diameter lenses you need bigger filters.
Another thing that u have pointed is that sometimes the lower side of a 4x4 grad may get in the frame, not that this is noticeable ...
Dimitrios Koukas
#4 David Mullen ASC
Posted 12 October 2005 - 02:14 AM
We had to get our 4x5 mattebox, anti-reflection filter holder, and 6 1/2" round Polas all shaved down in thickness in order to use them with all of our Primo anamorphic lenses without vignetting (and that barely works for the 35mm Primo anamorphic). But it's great to not have to use the 6x6 mattebox except for when I used grads.
Basically you'd want to rent both for a feature if possible. In general, it's better to stay small & light with the 4x5 mattebox and only use the 6x6 for when you need to use grads (because of the ability to raise and lower the grad.)
#5 Dimitrios Koukas
Dimitrios Koukas
  • 569 posts
Posted 12 October 2005 - 02:19 AM
I agree here, that's the best option.
Dimitrios Koukas
#6 Jon Rosenbloom
Jon Rosenbloom
  • 713 posts
Posted 12 October 2005 - 11:10 AM
Thanks David and Dimitrios and Max.
It's a student film, 22 pages. Arri includes the 4x5 matte-box in the basic package, but I don't think I can afford two sets of filters! There's going to be some day for dusk shooting, and I think I'll really need the grads for that (actually, I'm toying w/ the idea of nd.3 on the bottom and nd .6 up top, w/ a little sliver of clear space for the actors.). If I want to mix a grad w/ an ultra-con, then obviously the filters have to be the same size.
Do you not like the 6x6 because of its heft?
David, in your production notes you keep writing about shooting at a 2.8, but you're shooting anamorphic??
#7 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 12 October 2005 - 11:29 AM
The only problem with 6x6 is it's big and heavy, not ideal for hand holding either!
Stephen
#8 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 12 October 2005 - 07:05 PM
It's only the grads you need to have in the large size.
If it's low budget, if the 4X4 covers your lenses, have a 4X4 mattebox, filter series in 4X4 for ultra-cons, nd, 85 etc, and have the grads only in 4X5.6. They will cover most of your needs, the 6X6 I consider is an "extra" option.
If you have a zoom or some lenses that are not covered with a 4X4, then you need a 6X6 Matte box and all the series in 6X6...
#9 Dimitrios Koukas
Dimitrios Koukas
  • 569 posts
Posted 13 October 2005 - 02:03 AM
Hello,
David,
How did you shaved them down?
Do u mean the metal ring?
Dimitrios Koukas
#10 David Mullen ASC
Posted 13 October 2005 - 04:43 AM
Hello,
David,
Dimitrios Koukas
Yes, Panavision filed down the metal to make the ring less wide, etc. so I could suck back the mattebox closer to the lens.
