DVX100a now or HVX200 later?
#1 David Beier
David Beier
  • 21 posts
Posted 13 October 2005 - 04:10 PM
I had plans recently to purchase a DVX100a as I've worked with it many times before, shot some fairly pretty stuff, and feel I know the camera well. Now, it seems there is a new model coming out called the HVX200 which will still be in the $5000 range and I'm wondering if it's worth waiting.
So, assuming that I'm a five-year-old who understands very little about cameras, what exactly are the key differences between the two cameras and what do they mean for someone one a limited budget? Also, how does the HVX200 compare to the Cannon XL2?
#2 Joshua Provost
Joshua Provost
  • 71 posts
Posted 13 October 2005 - 05:40 PM
David,
The obvious is that the HVX200 shoots HD and the DVX100A SD. You'll have to consider what your workflow will be like, since you need to use P2 memory cards for shooting HD.
HVX200 also has some cool features, enabled by the memory cards, such as variable frame rates. It shoots a lot of HD formats, and can record to miniDV tapes for SD. Perhaps you can pick up an HVX200, and shoot SD, until the HD workflow works itself out?
Otherwise, it looks like Panasonic has done a good job of making the HVX200 very familiar in operation to anyone who has used the DVX100 series.
Josh
#3 Delorme Jean-Marie
Delorme Jean-Marie
  • 513 posts
  • paris, france
Posted 23 October 2005 - 05:33 PM
an other advantage for the new panasonic if you work sd it's with an hd chip and it does hd in progressive.
it only alows 3 chips of 8 mn each that you can download on a dedicated item.
#4 Josh Bass
Josh Bass
  • 552 posts
Posted 23 October 2005 - 05:46 PM
NOT within the 5000 range. . .I believe it starts at $6000, and you still need some way to store your HD footage, either a hard drive system or the P2 cards. Either way, your cost is going up.
#5 BillP
BillP
  • 5 posts
Posted 25 October 2005 - 04:10 PM
Like the others stated.
If your gonna be shooting SD for a couple more years, get the DVX.
FYI, the DVX100B has been announced, and should be shipping any day now.
If you want to score the rebate deal with the DVX100A, you better act quick.
-BillP
