Bolex Viewfinder
#1 ochopatas
ochopatas
  • 16 posts
Posted 16 October 2005 - 11:11 AM
Hello,
I have a 16mm Bolex H16 reflex camera, with one 1 inch/25mm lens. Very simple.
My problem is that when the lens is attached tightly onto the turret, through the viewfinder, nothing is ever in focus. It is NOT a problem with the diopter. Everything is blurry regardless of the focus ring settings.
HOWEVER...
When I loosen the lens two to three turns, everything is now in focus through the viewfinder.
1) What do you think is the problem here?
2) What should I base my focus on? The measurements on the ring when correctly attached to the turret, regardless of what I'm seeing through the viewfinder, or should I leave the lens unscrewed a bit and trust the viewfinder?
I am going to try and get my film developed this week, but this is making me very nervous, because I don't like wasting film. Too expensive.
Edited by ochopatas, 16 October 2005 - 11:11 AM.
#2 Herb Montes
Herb Montes
  • 225 posts
  • Gulf Coast of Texas
Posted 16 October 2005 - 05:07 PM
Hello,
HOWEVER...
Is this a Rx lens you're using? If not then it will not focus right because the reflex prism makes the lens mount deeper. You have to use lenses made for the Rex camera, especially lenses under 50mm.
#3 ochopatas
ochopatas
  • 16 posts
Posted 16 October 2005 - 06:27 PM
I've never heard of the maker of this lens before, this is all it says: "Kinic Anastigmat 1 inch f/1.5 "
No place does it say whether it is a rx lens or not. Not sure how I'd find out!
Even if it were not, do you think it would affect the film? Or does the kind of lens only affect the ability to see an accurate focus through the viewfinder?
#4 ochopatas
ochopatas
  • 16 posts
Posted 16 October 2005 - 07:42 PM
Additionally, it has, etched into the barrel, "VS" I assume for variable shutter? I know there was a line of RXVS lenses, but I don't think this is what that is. Arg.
I really hope that my 3 rolls of film turn out somewhat decently. I've never worked with film before, and this hasn't been a great start. I blame my professor for not listening to me when I told him that something was wrong with the image.. :angry:
#5 Tim Shim
Tim Shim
  • 50 posts
Posted 17 October 2005 - 07:08 AM
ochopatas, it seems like you will get an out-of-focus image. The lens on your Bolex is likely not a RX lens and will not focus properly through the viewfinder.
Tim
#6 Herb Montes
Herb Montes
  • 225 posts
Posted 17 October 2005 - 01:01 PM
Lenses for the Rex line of Bolex cameras include Switar, Schneider and Som Berthiot. I got Rx Schneiders on my Rex5 and I acquired a Berthiot 50mm Rx off ebay for less than $15.
#7 lluis
lluis
  • 63 posts
Posted 17 October 2005 - 02:11 PM
[quote name='ochopatas' date='Oct 16 2005, 04:11 PM' post='71301']
2 or 3 turns!!?? Too much. You have a big problem with your lens, but nothing to do with RX lens... (I use many non RX lens in rex Bolexes and non problem with focus, just disfocus in the corners, that disappears closing 2 stops). Try with other good lens to discard a back focus camera issue (anyway it'd be a too short distance issue... very rare, at less anyone had manipulated it).
All the best
