shooting the stars
#1 ivan delenda
ivan delenda
  • 17 posts
Posted 16 October 2005 - 01:23 PM
Hello,
i will be shooting soon in a desert, some of scenes are basicly night-shot stars.
my producer told me that it s impossible to get stars on a film , and he said i have to find alternative ways ...
is that true ?
if not , anyone knows , if it s possible, and what s the tric , shutter speed, lens , and film i have to use ?
thanks
ivan
#2 Joseph White
Joseph White
  • 143 posts
Posted 16 October 2005 - 01:51 PM
i'd say shoot 5218, push it one stop, and get yourself a set of nice fast lenses - like zeiss super speeds or master primes if they're avilable where you are. i'd also suggest, if you have the film and the time, that you bracket exposures (shoot at a couple different f-stops) just to give yourself a little wiggle room in post. if the stars are nice and bright - especially somewhere like the desert where there isn't a lot of light pollution, you should definitely see them.
best of luck!
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 16 October 2005 - 02:09 PM
Hello,
is that true ?
thanks
ivan
If there is no Live Action acting its very easy, just use a slow frame rate!
Stephen
#4 Dickson Sorensen
Dickson Sorensen
  • 131 posts
Posted 16 October 2005 - 02:29 PM
Don't expect to discover any new galaxies this way.
#5 David Mullen ASC
  • 20073 posts
Posted 16 October 2005 - 03:26 PM
I don't think you'll get bright enough stars on a movie camera except when doing time lapse, and then the stars rotate across the sky visibly. Usually this would be an efx shot. You could even do it yourself with double-exposure if the shots are locked-off and you can create a realistic starfield -- small pinholes punched into a black showcard, backed with diffusion (like tracing paper) and backlit. The key is finding a realistic size for the pinholes -- smaller is better, but not so small that they can't show up.
If this is for video only, then just combine them or add them in post. This is assuming you are adding stars to a day-for-night or dusk-for-night landscape. If you are only shooting stars in the sky with no landscape, then just fake it with the pinholes-in-black card technique (if for print) or create them in a computer (if for video only).
#6 ivan delenda
ivan delenda
  • 17 posts
Posted 16 October 2005 - 03:48 PM
thanks guys,,,
i cant afford very speed Zeiss, so i ll go for double exposure.if i ll discover any new galaxy , i ll make you know :)
#7 Dickson Sorensen
Dickson Sorensen
  • 131 posts
Posted 16 October 2005 - 03:55 PM
If you hang clear film leader in an array behind the cards you can make them twinkle.
#8 ivan delenda
ivan delenda
  • 17 posts
Posted 16 October 2005 - 04:07 PM
what if i have Konvas 2m ? i there any special advice ?
Edited by ivan delenda, 16 October 2005 - 04:09 PM.
#9 Ilmari Reitmaa
Ilmari Reitmaa
  • 71 posts
  • Helsinki, Finland
Posted 16 October 2005 - 06:51 PM
Just to throw in some numbers, nightsky photographs with stars visible usually have specs something like f/2.8, ISO 800, 4-10 secs exposure plus you only get stars in the brighter range - if you're located well outside any urban light pollution. The faintest stars visible to naked eye are some ten stops below the brightest. So you'll definitely be better off doing double-exposure, as suggested.
