Kodachrome 16mm
#1 Will Montgomery
Will Montgomery
  • 2069 posts
  • Dallas, TX
Posted 17 October 2005 - 12:27 PM
Since Kodachrome Super 8 is disappearing, I thought I'd try 16mm Kodachrome with my K-3.
Only problem: my K-3 doesn't have a 85b filter and I'm wondering if I really need it since I'm never projecting the film... I always transfer and color correct with a good local Telecine shop.
Is it worth losing the sensitivity if I'm correcting the color anyway?
#2 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 17 October 2005 - 12:31 PM
Since color reversal films have so much less latitude than color negative films, you should always match the film to the light source, unless you are wanting a different "look". Shooting tungsten balance K40 in daylight without the orange filter will give a very cold color balance, that will not be fully correctable. Even with color negative, optimum color is usually obtained by matching the film and light source.
#3 A.Oliver
A.Oliver
  • 348 posts
  • Croydon UK
Posted 17 October 2005 - 12:35 PM
Think you may need an 85 not 85b.
(16mm k40, use it before you loose it)
#4 David Mullen ASC
  • 20069 posts
Posted 17 October 2005 - 12:41 PM
You need to use an 85 correction filter outdoors in daylight since K40 is tungsten-balanced for 3400K. Otherwise you'd end up with a blue-ish image that would be hard to correct in a telecine transfer since reversal has such limited latitude. If this is for direct projection, you definitely need to shoot in the color balance you want since there are no further correction steps.
The smaller color-correction filters are cheap; you can even get them used. I don't know what size your camera lens needs though.
#5 Will Montgomery
Will Montgomery
  • 2069 posts
  • Dallas, TX
Posted 17 October 2005 - 04:14 PM
I would use the standard Zenit K-3 lens, 7.5mm in diameter (or close to that). I'm sure there are some 85 filters available somewhere.
Thanks for the input.
#6 Will Montgomery
Will Montgomery
  • 2069 posts
  • Dallas, TX
Posted 23 October 2005 - 07:43 PM
I take that back, 77mm. Just ordered the $45 85 filter from B&H.
#7 Steve Wallace
Steve Wallace
  • 163 posts
  • Burbank, CA
Posted 23 October 2005 - 08:03 PM
If you want to see what K40 looks like, shot with no filter and corrected in post check out this first half of my short Tempest Fugit . You'll see, it's very diferent than the traditional kodachrome look we are all used to.
BTW the rest was 7240 ektachrome, and the new Tri-X
#8 Anthony Schilling
Anthony Schilling
  • 1063 posts
  • Portland, OR
Posted 23 October 2005 - 08:34 PM
Are those the Kelso Dunes?
#9 Steve Wallace
Steve Wallace
  • 163 posts
  • Burbank, CA
Posted 24 October 2005 - 12:32 AM
No, this was south of Kelso in the Imperial Sand Dunes, on the California, Arizona, Mexico borders. Between Yuma, AZ and El Centro, CA. The same location they used in Return of the Jedi.
