750 as good as F900?
28 replies to this topic
#1 Jason Chan
Jason Chan
  • 8 posts
Posted 17 October 2005 - 09:39 PM
The rental house has suggested that I should take up the F750 instead of F900 as he mentioned that they are the same if I'm going to shoot on 25p.
I know the F900 is the camera of choice for a lot of features, but not much has been heard of the F750 compared to the 900.
Can anyone tell me what's the difference between them? and if there is a significant quality improvement using the F900?
Thanks for any feedback given.
#2 Clive North
Clive North
  • 8 posts
Posted 18 October 2005 - 04:47 AM
Hi Jason - I have a 750 here in the UK and the way I would look at it is the F900 is the better camera certainly for transfer to film for large screen projection (George Lucas seems to know what he is doing after all!)
The 750 is excellent for 25p for television and I can see know reason to go for the more expensive option in that case.
Hope this helps,
Clive North
#3 Jason Chan
Jason Chan
  • 8 posts
Posted 18 October 2005 - 11:04 AM
thanks for the feedback.
We intend to do a film transfer. So I guess F900 will have a significant quality improvement over the 750 for such purpose. Correct me if i'm wrong.
#4 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 18 October 2005 - 01:09 PM
The F900 is far better than a 750. IMHO they are in a different league.
Stephen
#5 Jason Chan
Jason Chan
  • 8 posts
Posted 19 October 2005 - 08:59 PM
Thanks for the input.
Good thing I check with you guys here. Otherwise, I would have been "persuaded" to use the 750 by the rental house.
Thanks again!
#6 MDO
MDO
Posted 08 November 2005 - 12:50 PM
Thanks again!
Hi
If you recording in HDCAM mode ie, using the on-board VTR the differences between the two are marginal.
The f900 head is 12bit. The 750 is 10bit. But... BOTH are downconverted to 8bit to get onto the HDCAM.
Both are compressed at 4.4:1
The f900 has a more robust lens mount and slightly improved prism (as well as all the extra speeds).
By the time you have xferred to film, these benefits are all but lost.
However, if you are doing CGI you ideally need to record direct to an external no/low compression 4:4:4 VTR, not HDCAM. But then you would be using a 950.
MD
#7 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 09 November 2005 - 04:13 AM
Hi
I do not agree that the difference between a 750 and 900 is marginal.
HD Cam records 3:1:1 Then it is compressed @4.3:1.
Stephen
#8 MDO
MDO
Posted 09 November 2005 - 06:58 AM
Stephen
Stephen, the compression figure of 4.4:1 is taken from Sony's own spec:
www.cinealta.com/product/acquisition/pdf/HDWF900_e.pdf
My point is that the small differences between camera head, once squeezed onto HDCAM fail to show up in a big way. It's wishful thinking to believe otherwise. Why bother to go to all the hassle of external 4:4:4 decks if HDCAM is so great? A couple of extra bits of quantization will not make a world of difference once re-quantized to the 8-bit HDCAM standard. ..add a 35mill transfer to the equation (as opposed to a decent HD projector) and anyone will tell you that you would be very hard pushed to tell the difference.
MD
#9 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 09 November 2005 - 07:42 AM
MD
I think the camera head on the 900 is a very important issue! Shooting for a film out from a 750 will look far worse than from a 900. Have you tested the cameras next to each othe? Its Day and Night in my opinion!
Film transfered to HDcam on a Spirit looks better than the output from a 750 or a 900 in my opinion. If HDcam was the limiting factor that would not be the case!
Stephen
#10 MDO
MDO
Posted 09 November 2005 - 12:16 PM
Stephen
What aspects of the image look "far worse" on 750 film out?
HDCAM is most definately a limiting factor, especially where CGI is needed. Recording the native bit depth at 4:4:4 with no compression will give the absolute best images. HDCAM does not do this.
I don't get your film to video analogy..a 35mm neg has a much higher native resolution than HD. This will show up on an HDCAM transfer, thats why it looks better than the playback off an 750 or 900. HDCAM is not the lowest common denominator in this respect... big differences between formats (HD vs neg Film) will come through to some extent, small differences (10bit vs 12bit) will not (unless you are filming test charts!). The whole arguement is academic if the entire film to screen process is taken into account. This is where 35mm die-hards come unstuck...yes, 35mm has a higher native res. than HD, but by the time it reaches the big screen, you are back to an effective res. of 2k (plus grain, weave, dirt and scratches) . An HD projection of HDCAM on a Barco wins hands down.
The original question was about the technical differences between the two cameras. Fps choice aside (and that is a big aside), the differences do not amount to much when shooting real life, not test charts. I have seen both, digitally projected using real life footage and no-one could tell the difference. You may be able to spot the difference, switching between the two on monitor when looking at a locked-off test card, but does this amount to 'night and day' for reality? Most of the differences between the two are more to do with clever marketing than huge technical differences. Check out the respective brochures to see why....then read the smallprint in the spec.
MD
#11 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 09 November 2005 - 01:57 PM
MD
I have been very dissapointed with the 750 & 730, I feel they look like DigiBeta. Ok that was using HD zooms not Digiprimes.
Just my personal view!
Stephen
#12 Jason Chan
Jason Chan
  • 8 posts
Posted 16 November 2005 - 09:37 AM
Great information so far.
I'll be using the F900 with HD zooms only. I hope it doesn't look like Digibeta.
and btw MDO, that's the exact thing the rental house told me. That I should go for the 750 to save cost since i'm not doing any CGIs.
Stephen
Edited by Jason Chan, 16 November 2005 - 09:42 AM.
#13 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 16 November 2005 - 09:58 AM
I don't think you will regret spending a bit more on origination.
I never heard anybody say its a shame we shot on 35mm, it would have looked better on.........
Stephen
#14 MDO
MDO
Posted 21 November 2005 - 07:44 AM
Of course it won't look like digibeta, and neither would a 750. There is something seriously wrong if an HD format ends up looking like an SD format! I dont know how Stephen was viewing his 750 material, but there is no way a 750 looks like digibeta. Maybe if the detail settings are set wrong it will give a video look, thats all I can think would do it. I say again, check out the spec on these cameras.
#15 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 21 November 2005 - 09:02 AM
Shooting with the 970 DigiBeta today. I would say it looks better than the 730/50 range!
Stephen
#16 Filip Kovcin
Filip Kovcin
  • 4 posts
Posted 20 December 2005 - 07:49 AM
Stephen
hello there, mailing from poland.
i am using both 750p and f900 cameras. in tv world i cannot say that there is visible difference between the two. if you are using both cameras with the same path from start to end.
the think where you CAN see "BETA" look is ofcourse when shooting in interlace and then downconvert to standard definition. then, in my personal opinion, it really looks like beta. which is probably normal due to interlace origin. BUT, of course, as you all know here when shooting in progressive mode (either f900 or 750p) camera, there is no way to look like beta.
the only difference i can see somehow exist - is when you look at 750p material on the big screen (after transfering to 35mm) and have really bright parts in your shot - window etc. together with normal exposure situation - in those situation (but, again this is maybe subjective opinion) i saw difference in treating bright parts. f900 had better response to those details in bright lights. but i did not tested them side by side. this is opinion i get when saw two different polish movies shot on our cameras but with somehow similar lighting conditions. (normally or dark lited interior with bright exterior in the same shot)
but
the problems starts when hd is DOWNCONWERTED to SD. it really depends how is downconveerted. there are many ways to do this and of course results are different. (f500, computer downconversion, jh3 player, etc.) and if you are asking me - wrong approach in this moment can result in bad impression. recently (3 days ago) i did that with f900 and downconwerted material looked in some way worse than PAL signal (imx). i believe that that is similar with 970 digibeta (thismodel 970 is NOT 790!!!!) which has progressive mode (imx too), of course.
my "theory" is that if you are working for TV - it's better to work with 970, imx or other progressive cameras - if you cannot achieve PROPER downconverting path. working with HD material eiter f900 or 750p if downconverted badly will in my opinion deliver not so impressive picture. the answer is maybe simple (i am not engeneer or tv electronic guru, just user) if there is no downconversion - signal is untouched. if donconverted it MAY add artifacts...
another aspect of "beta look" is ofcourse DOF issue, but this is another story.
just my thoughts.
thanks,
filip
Edited by filip kovcin, 20 December 2005 - 07:56 AM.
#17 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 20 December 2005 - 08:20 AM
just my thoughts.
thanks,
filip
The DOF issue is identical with any 2/3 inch chip camera! Am I missing something?
Stephen
#18 Filip Kovcin
Filip Kovcin
  • 4 posts
Posted 20 December 2005 - 10:37 AM
Stephen
Stephen,
of course, i just forgot to mention that i was thinking of 35mm DOF comparing to 2/3" DOF.
note: jump over following part if ewerytnig is clear for you
2/3" DOF "look" is 2/3" look, not 35mm DOF look...
i just wanted to say that 35mm camera will always have it's own (of course) film look DOF, but 2/3" cameras, even when progressive, even if HD will always have that 2/3" - "digital" DOF look. i mentioned that because sometimes is difficult to explain to i.e. client, that despite all quality HD brings it will see it's own world in it's own way - which is connected with 2/3" sensors. so if someone is expecting DOF of 35mm in all situations - when shooting with 2/3" cameras - he is of course rather wrong. you can mimic film DOF by choosing proper focal lenth etc, but as you all know this is not possible always, due to (still existing) laws of physics :)
thank you,
filip
Edited by filip kovcin, 20 December 2005 - 10:41 AM.
#19 MDO
MDO
Posted 02 January 2006 - 04:00 PM
Stephen
Stephen
Are you seriously saying that SD 25P rushes off a 970 viewed on a studio SD monitor look better than non-downconverted HD 25P rushes off a 750 viewed on a studio HD monitor?
#20 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 02 January 2006 - 04:13 PM
Stephen
I would like to see a direct comparison with the 970 up converted to HD, and the 750 downconverted to SD, with the same lens on both cameras.
I am fairly sure for Blue screen the 970 results would be better for an SD finish.
Stephen
