ASA Rating For PD-150
#1 Mike-In-MT
Mike-In-MT
Posted 17 October 2005 - 09:42 PM
Does anyone have an ASA Speed for the PD-150? I need it to choose a base F-Stop for my lighting design? Any help is greatly appreciated.
Mike Burchett
#2 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 18 October 2005 - 03:31 AM
I guess the specifications must be 2000 lux N = 10 (11-1/3) typically (Power HAD Sensors) , set your meter to 640 or 500 ISO. If it's only to have a base to work on, you'll be fine.
seems like it's not easy to find the specs of this camera - Sony gives a minimum sensitivity that assumes at least a + 18 dB gain and even considering that, that goes to 2000 ISO ! So there must be at least one stop that comes from somewhere else (low speed ?) I don't know
http://www.mediacoll...ra/dsrpd150.pdf
If you want a more precise setting, you can figure out by yourself, depending on what you've got : meter ? luxmeter ? waveform monitor ?
Search on these forums, the way to do it has been discussed several times. If you don't find that, ask again.
Regards,
