super8 colour neg processing
#1 Richard Tuohy
Richard Tuohy
  • 482 posts
  • Daylesford, Australia
Posted 19 October 2005 - 09:09 AM
There is no neg lab in australia that currently offers super8 neg processing. Just how difficult would it be for a lab set up for 16mm and 35mm to offer super8 neg processing. Same chemicals. And its not an issue of sprockets. I believe it is something to do with ajusting tension ... but I don't know how much of an obstacle that is. Could it at least be attempted on a 16mm machine? I wonder if it is an issue of the film breaking during processing.
#2 John Pytlak RIP
John Pytlak RIP
    (deceased)
  • 3499 posts
  • Rochester, NY 14650-1922
Posted 19 October 2005 - 09:37 AM
The machine used would need to be "tendency" drive, using soft touch tires. Any rollers would need to be properly undercut for 8mm film. Unless the machine is purpose-built for 8mm, a film twist could easily occur on rollers wider than the film. Likewise, tensions need to be carefully controlled so as to not break the film or splices.
#3 Dominic Case
Dominic Case
  • 1357 posts
  • Sydney Australia
Posted 19 October 2005 - 05:44 PM
John is right about needing tendency drive machines (ie not sprocket drive). But even tendency drive machines have a number of guiding rollers that are cut to 35mm and 16mm: these would need to be changed. Also, the tendency drive rollers have a dimple structure to support the film, and 8mm film would not be properly supported unless the dimples were a lot smaller.There would be a strong risk of twists, scratches and other misfortunes.
Unfortunately, I don't believe there is enough super-8 negative work in Australia to make it a viable proposition for any of the commercial laboratories to set up a dedicated machine with completely different rollers, tension settings, replenisher rates etc. It's one of the penalties of being a relatively small population relatively far away from other populations. But someone with a passion and a spare processing machine may always prove me wrong!
