Arri S Serial Numbers
29 replies to this topic
#1 Alex Corn
Alex Corn
  • 36 posts
  • Digital Image Technician
  • NYC
Posted 20 October 2005 - 10:12 AM
I know this is a long shot, but I am doing an inventory of 160 some-odd arri-s's and sb's and I would like to know if anyone knows where i can find the hostories of certain Arri serial #'s. I need to know of mechanical differences in certain models made in certain years, if the serial numbers reflect any kind of chronology, etc etc. If anyone can help, it would be greatly appreciated. Thanks.
#2 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 20 October 2005 - 11:56 AM
Would you like owners to give you informations on their own ones ?
I can have a look at mine, two 16 ST, and give you the serial numbers if you like
#3 Alex Corn
Alex Corn
  • 36 posts
  • NYC
Posted 20 October 2005 - 04:35 PM
Im more or less looking for something along the lines of the differences in production that occured over the history of Arri s/sb manufacturing. For instance, all the newer model s's run the ground (negative) current through the body of the camera, eliminating the need for extra wiring from the battery to the motor and mag connection. But I found an older model Arri bearing the serial number 063. It does not ground through the camera but uses extraneous wiring. Since it is so old, and has a low serial number, I figured that maybe the serial numbers are chronoligcal, and if they are than I want to find a list of all the changes to different manufacturing batches by serial number. I repair these cameras for a living, and in diong so have found that every Arri s/sb has it's own little quirks, and parts from some are totally incompatible with parts from others. Seeing as I have 160+ to keep track of, knowing which of mine are different internally without having to rip them apart would be a great help. If you have original manuals that mention anything along these lines, that would be an awesome help, and also if you know how your camera is inside (mainly diopter format, motor bushing mount, buckle trip connects, and roller config), and provide your serial number, that would be awesome. I figure this is a long shot, but I've been browsing this site and found the info good, so I figure its a good a place as any to find out.
#4 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 20 October 2005 - 04:49 PM
I know the inside quite well.
I'll check the serial numbers and give you descriptions on what I've got in a few days.
Regards
#5 Alex Corn
Alex Corn
  • 36 posts
  • NYC
Posted 20 October 2005 - 04:52 PM
Regards
That would be great. Thanks much.
#6 Annie Wengenroth
Annie Wengenroth
  • 653 posts
  • Sound Department
  • Brooklyn, NY
Posted 20 October 2005 - 07:41 PM
Out of curiosity, do the older Arri S models have the serial number in a little circle on the inside of the door, or is that something else? The only number I could find on mine was 115.
Yeah. And then it got stolen. :sigh:
#7 Tim Carroll
Tim Carroll
  • 2171 posts
  • Chicago, Illinois
Posted 20 October 2005 - 09:19 PM
Just out of curiousity, how did you come up with 160 Arriflex 16S and 16S/B cameras? Are you the camera repair tech at NYU?, or maybe UCLA?
-Tim
#8 Alex Corn
Alex Corn
  • 36 posts
  • NYC
Posted 21 October 2005 - 10:18 AM
"Out of curiosity, do the older Arri S models have the serial number in a little circle on the inside of the door, or is that something else? The only number I could find on mine was 115.
Yeah. And then it got stolen. :sigh:"
-I take the bumbers off one of four places: the lower left side of the body along the bottom, under the battery terminal, inside underneath spindle spring/chain cover, and underneath the pressure plate assembly.
quote name='TimCarroll' date='Oct 20 2005, 10:19 PM' post='71908']
-Tim
[/quote]
-I am the camera repair tech for New York Film Academy.
#9 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 11 December 2005 - 03:57 PM
Ok, then here are mine serial numbers :
ST n° 17790 and ST n° 10852
I think Tim might as well give you a number.
What do you need to know about the ones I've got ?
#10 Tim Carroll
Tim Carroll
  • 2171 posts
  • Chicago, Illinois
Posted 11 December 2005 - 06:03 PM
The serial number on my Arriflex 16S is 73XX and I know it was made in 1957, because it came with all the original paperwork from when the guy bought it, as well as an ARRI brochure from that year. Mine has the different back side and no sync pulse socket. See below:
-Tim Carroll
#11 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 11 December 2005 - 08:00 PM
We almost could see the number on your picture, actually. Funny you don't give it all ! ( He's given me the whole number, who wants to bid ?) :lol:
Anyway, mine, that are more recent, look very similar. Only the "magazine" part shape is a bit different. And they've got the pulse socket.
I figured out from the number, compared to mine, that your camera is pretty old. Does it work well, anyhow ? You told us you were rebuilding it. So it turned OK ?
#12 Tim Carroll
Tim Carroll
  • 2171 posts
  • Chicago, Illinois
Posted 11 December 2005 - 10:02 PM
Yeah, it turned out great. Got assistance from two very generous German Arri techs who worked on the cameras back in the 1960's at the factory. Has been a wonderful learning experience for me, and has given me alot more confidence in the camera.
It's weird how the numbers go. I saw one about six months ago with the serial number of 06XX, so you would think it was one of the earliest ones made, but it had the same kind of "magazine part shape" on the back as your later models do. Then I thought maybe mine was some kind of weird fluke, because I have rarely seen that kind of webbing around the "magazine part shape", but then I looked at the 1957 catalogue and all the 16S's shown had the webbing like mine. It's odd. Mine also has the drive springs for the spindles exposed and does not have secondary rollers mating up to the main rollers, it just has slides. Maybe when they came up with the covered drive springs and the secondary rollers and the different "magazine part shape", they started the numbers back over at zero again. It's weird that they call all of them Arriflex 16S though, except the bayonet mount ones.
-Tim
#13 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 12 December 2005 - 08:22 AM
Mine is labelled 16 ST, not 16 S, by the serial number. It has the 3 lenses mount. Does your have the 3 lens mount ? I feel like not but I can't really tell by the picture.
#14 Tim Carroll
Tim Carroll
  • 2171 posts
  • Chicago, Illinois
Posted 12 December 2005 - 09:12 AM
Mine has the three lens turret. I had always figured that the ST was the European version of the S, but then I have seen many individuals selling 16S cameras from over in Europe and occasionally an ST will turn up here in the States. Mine does not say ST on it and it does not say S on it anywhere. The only thing by the serial number is an "Nr" before the number. Does ST appear after the number on yours, or before? And are you sure that ST is not French, German, Italian, Dutch, Swedish or some other language abbreviation for serial number?
Here's a shot of the front of my camera. It still has the old aluminum port caps, very vintage. B)
-Tim
#15 Alex Corn
Alex Corn
  • 36 posts
  • NYC
Posted 12 December 2005 - 03:33 PM
Thanks for the info guys - it seems that the older cameras I have (four digit serial numbers) have the wierd webbing and only two roller drums. But I can't make any other patterns out. I have some that start with an NR and some that start with an ST (I'm still looking for an S, but I've only checked maybe 20 out of the whole 160) and it seems like the ST's have higher serial numbers. As far as the camera with the 73xx serial, that is odd. I have none like that. The lowest serial number I have is 0057, and it is so old it has the nuetral wire connected at the battery, instead of too the casing like every other S i have. Thanks again, and hopefully someone can verify what Ive found about the NR/ST nomenclature.
#16 Tim Carroll
Tim Carroll
  • 2171 posts
  • Chicago, Illinois
Posted 12 December 2005 - 03:51 PM
Sorry if there was confusion, it is a four digit serial number starting with Nr 7300. I was told years ago not to give out entire serial numbers of cameras on the web. I don't know if this is still going on now, but about five years ago I heard about a number of individuals taking down the serial numbers of cameras and then reporting them stolen. Since most of us cannot possibly identify everyone who owned these old cameras before we did, sometimes these crooks were successful. And even when they were not, they caused serious headaches for the individual who purchased the cameras. So I paranoidly never put down the whole serial number of any of my cameras on the web.
-Tim Carroll
#17 Alex Corn
Alex Corn
  • 36 posts
  • NYC
Posted 12 December 2005 - 05:19 PM
That's something I never considered...good advice. Some people in this world, I tell ya.
#18 Laurent Andrieux
Laurent Andrieux
  • 1527 posts
  • France
Posted 12 December 2005 - 06:05 PM
OK, I see, thanks for the advice...
#19 Tim Carroll
Tim Carroll
  • 2171 posts
  • Chicago, Illinois
Posted 15 December 2005 - 12:02 PM
Just found out some more information. My camera is Nr 7300, and I was looking at a camera today that is Nr 7900, somewhere between these two cameras is where ARRI changed over. My camera Nr 7300 has the webbing on the back of the casing and the slides inside instead of the rollers, and no "lock" for the power cable at the rear. His camera Nr 7900 has the new smooth back of the casing and the rollers inside instead of the slides, and has the "lock" for the power cable at the rear. So somewhere in that 600 serial numbers from my camera to his, ARRI changed over from the old style to the new style of the Arriflex 16S.
Just thought I'd pass it along.
-Tim Carroll
#20 Sam Wells
Sam Wells
  • 1751 posts
Posted 15 December 2005 - 12:22 PM
There were 3 generations of ground glass also IIRC. (don't quote me; there's only so much info on old cameras I can retain in the brain before I have to delete it to free up space :)
I have s/n St 15XXX -- heh heh -- made in ~ 1967 (according to Arri), I think just prior to going to the S/B.
The only "anomoly" I can see is the door latch is only marked "C" and "O" no Zu und Auf here !
THE most reliable _machine_ of any type I've ever owned, for sure
ps I saw Arri S serial no. 010 for sale at the old General Camera in NYC once.... looked pretty clean actually...
