Tow dolly instead of process trailer?
#1 Luke Prendergast
Luke Prendergast
  • 491 posts
  • Victoria Australia
Posted 20 October 2005 - 04:44 PM
Anyone have experience using a tow dolly on the streets? It looks like it would be a lot less obtrusive than a 2 lane wide process trailer, but still reasonably flexible, and it would free up the actors from having to drive. I'd be using it with a conventional hood mount and hostess tray. Rigid towing is something else I'm considering. Must check regs.
#2 Delorme Jean-Marie
Delorme Jean-Marie
  • 513 posts
  • paris, france
Posted 20 October 2005 - 05:01 PM
don't tell me the road was open to the traffic by the time this still was taken?
#3 Bob Hayes
Bob Hayes
  • 1087 posts
  • Culver City, California
Posted 21 October 2005 - 02:45 AM
Tow dollies work pretty well. However, it is hard to find them that are low enough. The tow dollies used by tow companies are pretty high making the front end of the angled up. Enough to be a problem. The tow dollies made for film word are exceptionally low and actually often drag along the highway
#4 Luke Prendergast
Luke Prendergast
  • 491 posts
Posted 21 October 2005 - 03:05 AM
I intend to build one for the purpose, so I can make it low. Maybe even pull the front wheels off the car. Don't worry I'll get it engineer stamped. I just picked that still off the Shotmaker site. No riding a crane on the back of a truck for me oh no.
#5 Stuart Brereton
Stuart Brereton
  • 3347 posts
Posted 21 October 2005 - 04:11 AM
I've used a thing called an 'A-Frame' for towing car before. It attaches to the front axle of the car (I think) and pulls and steers from there. Because the wheel are still on the ground, there are no problems with strange perspectives. If you're using it on a car with an auto gearbox, it must be in neutral (probably the best bet in any case).
#6 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 25 October 2005 - 03:55 PM
I've used tow dolly's before. They're not as convenient as an actual process trailer, but it sounds like you're just hardmounting anyway, so it should be fine. I actually did some fun stuff with a tow dolly and a technocrane a few years back. It was fun doing 270 degree moves around a moving car and actually seeing the ground at certain points.
I don't think you need to build your own dolly. I think you'll probably be able to rent one for much cheaper, and you won't have to worry about being held responsible if there is a problem with it.
Good luck.
