Bare-bones sounds for 8mm... Will this work?
#1 Erdwolf_TVL
Erdwolf_TVL
  • 104 posts
Posted 30 October 2005 - 07:39 AM
My budget is nil. I am not shooting for money, just for fun!
Any advice in this regard would be most appreciated!
Super-8 at 24 PFS.
Sound from a parallel mounted mini-DV camera (constantly running).
Once telecined, the video will be presented at 25 fps. So, there will be a significant sync gap between the audi and video signals from square one.
I intend to use the rattle from the 8mm mechanics to synchronise the sound and video start / end points.
Once I have calculated the length difference in millisenconds, I will squash the sound digitally to match.
I will at this point also apply a digital noice reduction filter to the audio track to reduce the rattle.
I will end up with video running 1 fps faster than it should and sound that is slightly higher pitched.
But at almost zero cost, it can't be too bad?
#2 Grainy
Grainy
  • 65 posts
Posted 02 November 2005 - 03:54 PM
I don't think noise reduction will reduce that sound as much as you'll hope and still make it worth while.
If it could, "fix it in post" wouldn't be the joke/bane of every location sound man out there.
Here's another suggestion: record the take with both super 8 and video, and as soon as you're done, use the video track as reference, over headphones, for your actors to self dub a clean track onto a different recorder. Try and get a better mic than the one that comes with your camcorder, too. Those tend to stink. I think amazon.com, of all places, sells a 40+ dollar shotgun mic that's not bad at all.
You'll have an easier time resolving the drift between the sound and picture with today's online cutting devices than trying to mass-conform a sound track.
Also, search the archives for a trick George Selinsky came up with on non-sync recording.
Anyway, however you do this, good luck! Post your results if you can!
G
