Lenses
#1 Miguel Bunster
Miguel Bunster
  • 301 posts
Posted 31 October 2005 - 12:46 PM
HI,
I am going out on production soon and have tested all my ideas on 35mm with standard speed Zeiss prime lenses which I like a lot. Now the thing is that I may get (almost sure) the Ultra Speed Z Set whichi si Zeiss too. I have never used them and it looks like I will not be able to test them. ANyone has worked with them? Can someone give me an idea of the differences? I understand they have more contrast. I wanted to test filters to make them much the Standards but as I mentioned, I will not have time to do this. Are they really different? I am finishing on print so I can't tweak the contrast in post. Any ideas would be great!
Miguel
  • 20072 posts
Posted 31 October 2005 - 12:50 PM
I don't find them to be particularly contrasty, nor low in contrast either. They can flare more easily, so watch bright lamps and windows (unless you like the flare.)
#3 Miguel Bunster
Miguel Bunster
  • 301 posts
Posted 31 October 2005 - 12:52 PM
Oo.. do they flare to much? I meand I will have some soft sources in frame like fluorecent lights on the roof.
Thanks!
Miguel
David,
Thanks! You posted just before I putted the question. I will have bright sources like windows, no direct light but yes... some time the lamps will be in frame and I cant do anything about flaging them out...
and to make it harder I will be shooting on 24-35mm lenses most of the movie.
Any ideas on how to avoid the flare?
Miguel
Edited by Miguel Teitelboim, 31 October 2005 - 12:53 PM.
#4 David Mullen ASC
  • 20072 posts
Posted 31 October 2005 - 01:06 PM
Well, how much flare is too much is a matter of taste. I can't tell you if you'll think it's a problem or not. It's much worse with the old Ultra-Speeds (the non-Z Series) than the Z-Series at Panavision. You'll probably be fine.
#5 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 31 October 2005 - 02:06 PM
As far as I'm aware Panavision's Ultra Speed lenses are rehoused Zeiss Superspeeds (at least those that open up to T1.3 or T1.4). The Superspeeds themselves are a bit more contrasty with faster focus drop-off than the Standards.
#6 Miguel Bunster
Miguel Bunster
  • 301 posts
Posted 31 October 2005 - 11:21 PM
What you mean by faster focus drop off?
The is less focus range back and front of the subject in focus?
Miguel
#7 Max Jacoby
Max Jacoby
  • 2955 posts
Posted 01 November 2005 - 03:47 AM
Yes. The difference between in focus and out of focus is much more noticeable than other lenses, say the Cooke S4s.
#8 David Mullen ASC
  • 20072 posts
Posted 01 November 2005 - 11:57 AM
More contrasty lenses like by Zeiss tend to make the delineation between sharp and unsharp more clear and abrupt as you roll or rack the focus. Now whether that's a good or bad thing is a matter of taste.
#9 Miguel Bunster
Miguel Bunster
  • 301 posts
Posted 02 November 2005 - 02:16 AM
Thanks!
