Aaton LTR 24/25 crystal synch
#1 jim bridges
jim bridges
Posted 01 November 2005 - 12:23 AM
I just purchased an Aaton LTR 7 #555 and need to know what postion the mini toggle switch should be in for 24fps synch. The switch is located on the back bottom of the camera next to the ASA dial. The Aaton manual doesn't specify if it is the right position or left for 24fps synch. Thanks for any help.
#2 andres victorero
andres victorero
  • 412 posts
  • Spain
Posted 01 November 2005 - 05:51 AM
I don´t know nothing about this cam but look the manual here:
http://www.my16mm.com/manuals.php
#3 jim bridges
jim bridges
Posted 01 November 2005 - 06:16 AM
Thanks Andres, I appreciate it. That is the manual I have and I must have looked at that a dozen times, but still no diagrams. Thanks, Jim
#4 Brian Drysdale
  • 5198 posts
Posted 01 November 2005 - 09:48 AM
If you're in a 50hz PAL region you could point the camera at a TV and try both settings. At 25fps the picture will be stable in the viewfinder.
My much modified LTR is slightly older and changing from 25fps to 24fps involves a screw under the motor retaining ring, so I can't help directly
Failing that give one of the Aaton agents a call, they're usually very helpful.
