shooting with S35mm gate
9 replies to this topic
#1 Valentina Caniglia
Valentina Caniglia
  • 49 posts
Posted 04 November 2005 - 01:19 AM
Hi all,
I am supposed to film a Bollywood commercial soon. The director asked me to rent a 35mm with a S35 gate.
I have two questions.
If I shoot with a S35 mm gate what ground glass I can use? Can I use a 1.85 marked ground glass?
If this commercial ends up in TV why someone would shoot with a S35mm gate?
Sorry for my basic questions but I have never shoot with a S35mm gate.
V.
  • 20069 posts
Posted 04 November 2005 - 02:47 AM
Well, if the film is only for telecine transfer, then why NOT use the whole width of the negative rather than set aside room for a soundtrack that is not needed? Most 35mm shot for TV is Super-35 (i.e. Full Aperture).
Full Aperture can be 4-perf or 3-perf. The 4-perf Full Aperture frame is 1.33 : 1 and the 3-perf Full Aperture frame is 1.78 : 1. You can use any groundglass you want with either to compose for 1.85, 2.35, 16x9 (1.78), etc. Shoot a framing chart for your colorist.
#3 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 04 November 2005 - 08:05 AM
Very Important if your not at the transfer.
Some older cameras such as Arri II and Arri III, the viewfinder does not cover S35 area. If the lense is re-centered, some (zeiss) lenses will hit the mirror.
Stephen
#4 Brad Grimmett
Brad Grimmett
  • 2660 posts
  • Steadicam Operator
Posted 05 November 2005 - 09:04 PM
A lot of commercials shoot BIG TV, which I believe is 4 perf full aperture. Someone please correct me if I've got this wrong. I don't do many commercials these days, but I remember a few years back BIG TV was the standard for most commercials.
#5 Patrick Neary
Patrick Neary
  • 873 posts
  • Portland, OR
Posted 05 November 2005 - 10:03 PM
Howdy- The 35 spots I shoot are all 4-perf super-35, we shoot 4:3 square-o-vision, but you can get a GG marked for any framing you like. There's really no good reason I can find not to shoot S-35 for TV spots, you get a bigger image area on the film.
A few older zooms may not cover the full image area, (someone mentioned the cooke 20-100 awhile back if i remember right) something easy to check during prep.
#6 Adam Frisch FSF
Adam Frisch FSF
  • 2026 posts
  • Los Angeles, USA
Posted 05 November 2005 - 10:16 PM
N35 is useless unless you're contact printing for a relealse print - why throw resolution away?
#7 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 06 November 2005 - 04:32 AM
If you look at the spec of today's zooms for Cooke & Arg., they only cover Acadamy 35, but in reality most cover S35 for 1:185 extraction.
Stephen
#8 Patrick Neary
Patrick Neary
  • 873 posts
  • Portland, OR
Posted 06 November 2005 - 11:31 AM
I suppose also you might be concerned about chromatic aberrations and softness at the edges and corners of your S35 frame with lenses designed only for academy coverage, especially for big-screen work.
Stephen, was it one of your cooke zooms that you said didn't quite cover S35?
#9 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 06 November 2005 - 01:02 PM
My Mitchell 35R3 is centered for acadamy, so I can't be sure. I did look at the spec of all current 35mm zooms, and not 1 covers, if you read the figures from the manufactures.
I know zooms are used all the time in S35 feature work so most do cover S35 1:185. I know series II/III cookes don't fully cover S35 acadamy but are fine S35 1:1.85 . Its a grey area.
A question was asked on CML about zooms 10 days ago, I mentioned about Cooke and Arg. not covering S35 acadamy. Nobody challanged my wisdom! Cooke is a sponser of CML, so I think you need to test!
As I have so much equipment, my local rental house is not very friendly, otherwise I would just pop in and try!
Stephen
#10 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 07 November 2005 - 03:49 AM
I've just had a look at my 20-100 Cooke. If I take off the front plate that says Taylor-Hobson Cooke Varatol 20-100 I am sure that it would be fine for S35 1:185.
Even without re centering the lens for S35 I only get the slightest vignetting on the left top and bottom of frame.
The Cooke 20-60 is the same!
Stephen
Edited by Stephen Williams, 07 November 2005 - 03:49 AM.
