Ways to avoid flare?
#1 Riku Naskali
Riku Naskali
  • 310 posts
  • Finland
Posted 04 November 2005 - 08:58 PM
Hi, I'm shooting a short film with old first generation Zeiss superspeeds that seem to be really prone to flaring. Obviously I have a mattebox and an eyebrow, but they aren't any good with wider lenses...
I've surrounded the camera with flags, but still there's light coming in. What more can I do? Obviously it doesn't get any easier due to my lighting style, mostly backlight or 3/4 back... I've shot with T1.3 - T2.8.
I've never seen lenses that flare this much, I can't even have kinos above the frameline...
  • 20072 posts
Posted 04 November 2005 - 09:19 PM
Learn to love it or don't have bright lights in the frame (darken or dim them)... or change lenses. That's about it. Sometimes you can get away with an ND grad or something to darken the bright area of the frame that is too hot.
#3 Michael Collier
Michael Collier
  • 1262 posts
Posted 04 November 2005 - 09:23 PM
Flag EVERY light you have in front of the lens. I dont know if this is nesicarily the 'proper method' but it always works for me. If you have a zoom on your camera and can pull back any, pull out until you can see all your lights. then put the flags in front of those hotspots, making sure they are far enough forward so as not to affect lighting on your actors.
if you cant pull out any get a ladder and put your eyes basicly where your light will be. then have an assistent adjust the flag until it completely blocks the lens in your veiw. all you are trying to do is to put a block the direct line between the lights head and the lens. if it still flares your flags are not big enough to cover the whole hotspot. cover the area of the light and at least 25% more, to cover the glow.
**edit** sorry, I just read Davids post. yeah if its in frame your out of luck, if its out then use my method
Edited by Michael Collier, 04 November 2005 - 09:24 PM.
#4 Dickson Sorensen
Dickson Sorensen
  • 131 posts
Posted 04 November 2005 - 10:16 PM
Flare can also come from sources other than lights. Bright objects, bounce cards, reflections off water, windows, mirrors and so on. A good matt box with a mask or black tape set to the edges can help.
