S16 Transfer
#1 Will Montgomery
Will Montgomery
  • 2070 posts
  • Dallas, TX
Posted 08 November 2005 - 06:54 PM
I'm doing an SD transfer of some S16 footage on Thursday. Good machine & good colorist. I'll be going to DigiBeta (for archiving) and miniDV for quick editing in Final Cut Pro.
Should I have them crop to 16:9 and then create an anamorphic image to tape like anamorphic SD footage from a DV camera? or should I just letterbox it? (hate to lose pixels...)
I'm asking this here and not in the telecine forum because more people seem to read this one...
Posted 08 November 2005 - 08:56 PM
Well, what is the end result for? That should determine whether you want to transfer & post in 4x3 letterbox or 16x9. If you plan on a DVD distribution, 16x9 would be a good idea.
#3 Robert Glenn
Robert Glenn
  • 247 posts
Posted 08 November 2005 - 11:03 PM
can't you crop it in post?
#4 Mitch Gross
Mitch Gross
  • 2873 posts
Posted 08 November 2005 - 11:15 PM
There is little to no reason these days to do anything but transfer it using the full 16x9 image. This is material that will go through a post route, in a basic version in your FCP system and then in a proper online further down the road. In both instances you should have the full image at full resolution to work with since either of these systems can be used to then convert the material to a letterbox within 4:3 if you should need it. So stay with the larger 16x9 anamorphic full frame for now and then only on final outputs would you ever drop to a lower resolution image like a 4:3 letterbox. The only use for such an image on an initial transfer these days would be in viewing dailies, but now it's just about the same price to get your dailies on a DVD dub as it is to get a VHS. The DVD looks so much better and the deck will auto-detect the 16:9 and put in the letterbox if you are viewing on a 4:3 screen. So a letterbox transfer should really be a thing of the past.
#5 Stephen Williams
Stephen Williams
  • 4708 posts
  • Europe
Posted 09 November 2005 - 04:20 AM
Always transfer 16x9 FHA then all the pixels on the tape are image. Otherwise you throw away 1/3 of the resolution.
Stephen
